Metadata
I currently use Media Centre Master to pull all my meta data for my tv shows and movies, and has all the information I want in the xml files.  Is there any way to use this metadata in plex rather than using the defaults?  Alot of the metadata I've received from freebase or the movie database is either incorrect or incomplete and there's no way to edit the cast.
Depending on the format of your XML files, if they are in XBMC NFO format, you might be able to use the following agent to import the data:
https://github.com/gboudreau/XBMC-Movies-Metadata-Agent-for-Plex
If nothing else you could always write your own agent to import the data from the xml files.
