After upgading to Win 10 version 2004, plex wil not work no more, missing file is MFPlat.dll.
Download file from the net and putting it in the right folder,still dont work What to do ??
Download an installation image of a regular Windows version and never try to use a “Windows N” version again.
You need to reinstall the Media Feature Pack from Microsoft.
Per their instructions:
For Windows 10 version 1903 and later, you can add the Media Feature Pack by going to Start > Settings > Apps > Apps and features > Optional features > Add a feature , and then locate Media Feature Pack in the list of available optional features.
Just rolledback the old windows version, and it it all work… can see what the problem with win 10 N version is…N is for Norwegian i guess ??
No, “N” means no Windows Media Player (WMC) and no Internet Explorer included.
But Plex needs a few codecs which come with WMC, so you need to install it anyway by means of the Media Feature Pack.
Doooh i see, sorry
Anyway it works now
I know now … sorry for the disturbance… all is ok now
