Minor issues with downloads section
iOS app has come a long way in reliability in downloads section but there are still some improvements to make it a seamless experience.
  1. Please add “select all” / “retry all” / “cancel all” option to downloads.
  2. There are issues with the way the app becomes unresponsive when low on storage. Perhaps there needs to be a max limit -5% idk,
  3. Add option for TV series to “Download Series” - currently u have to go to each season.
thank you for all the improvements already implemented.
Server Version#: 1.41.8.9834
Player Version#: 2025.14.0 (1037) [iOS 18.5] iPad14,10
2: you can manually set the max storage the app is allowed to use
Correct - but Max limit needs to be -5% of total storage available otherwise device stops responding due to full memory.
Example: 100GB memory available - the max allowed space to be used by app should be 95GB at maximum setting to ensure stability.
You can download Episode, Series and Show. Go to there actual poster Ellipsis in a compatible device.
Example: Series, Go to Series Poster.
I don’t see it…
