Ok, no problem. Thanks for passing it along.
@mbarylski said:
I got a mismatch again tonight after Hooten & the Lady finished recording. Seems like it has to do with the DVR rather than the matching.
@sa2000 said:
The evidence has been passed. The problem was not because of theandand&although it played a part - the issue is to do with the matching being done using the wrong year. Hence when you refresh the metadata it corrects itself - not sure if you need the Plex Dance or whether a refresh corrects anyway
There a fix that has just been released in Plex Pass Version 1.9.0
See Release Note
http://forums.plex.tv/discussion/comment/1514691/#Comment_1514691
- (DVR) Recorded shows were occasionally mistagged based on show year (#7328)
@sa2000 said:
@sa2000 said:
The evidence has been passed. The problem was not because of theandand&although it played a part - the issue is to do with the matching being done using the wrong year. Hence when you refresh the metadata it corrects itself - not sure if you need the Plex Dance or whether a refresh corrects anywayThere a fix that has just been released in Plex Pass Version 1.9.0
See Release Note
Yea, I noticed that…thanks!
