Missing Channel
Not sure where to place this… I wanted to report a misusing channel called DABL, channel 2.3, I believe it broadcasts from NYC. My antenna picks it up, but it is not in the listing.
You might try posting in this thread@sa2000 has been helping others get their EPG data…
Thank you… But this isn’t what I’m talking about. The thread you’ve linked is mostly about program guidea. My problem is actually about a missing channel scanned and found, but not listed in PLEX database/channel listing.
Yes, I understand what you are talking about… It’s still a guide problem… You scanned for channels and found them but you have one channel that doesn’t show in the program guide… Do you have anything listed for channel 2.3 in the guide??? In mine, I had a mismatch and had to use a dropdown box to choose the right one…
There is actually an online form here somewhere to report problems but I couldn’t find that… I have been following that thread and in the 714 posts, at this time, it has kinda become the most active thread for EPG problems of any kind…
I even mentioned the PLEX employee’s name in hopes that he would notice your post… I know he will need your zip code as well as the broadcast guide you selected…
No. I thin this is a fairly new channel, because there is no listing, there IS no guide. It’s not a "must have " channel for me, but at the same time, I’d like the guide added in the event something interesting comes up. There doesn’t seem to be an equivalent channel/sub channel.
Okay, I found this pinned post on reporting problems with EPG data
Thank you!!! This is what I need…
You’re very welcome… Glad I could help!!!
Hi
I can’t see any feedback forms from you
I need to know what zip code and lineup you used in DVR setup so i can check the channels.
DABL was added to some lineups yesterday morning
So sorry for the late reply. I guess the problem was submitted before. I had to move my antenna, and when I scanned again, the index was fixed! So, this issue has been resolved. Thanks so much!
