Server Version#:
I have two “mini-series”, which are equivalent to a long movie. The metadata continually incorrectly matches them. I have tried the imdb-**** and tvdb-**** and neither has worked. I have other “mini-series” that have matching metedata. The two series are Sci-Fi’s Alice from 2009 and Stephen King’s IT from 1990. Does anyone have any solutions? Thank you!
They may be an equivalent to a long movie but they don’t fit inside a movie library.
You have to put them in a TV library and name them with a s01e01 format according to the TVDB or TMDB
https://thetvdb.com/series/alice-2009/seasons/official/1
If you really want them in a movie library you would probably have to unmatch it and input all the information manually
Thank you for your assistance. I will give that a try. I am perplexed because I am only having issues with these two and like the others they ripped as movies not television series. Two others that I did not have issues with are Stephen King’s Rose Red and Colin Firth Pride and Prejudice. Thank you again.
