Server Version#1.41.3.9314
Player Version#:1.4.143.0
<If providing server logs please do NOT turn on verbose logging, only debug logging should be enabled>I have Plex server (with Plex Pass) on windows 11 with a HD Homerun Duo and Plex on a Fire tv. I originally set it up without OTA connection and had access on the EPG to Freevee and Tubi, etc. I connected the OTA antenna and now the EPG only shows the OTA channels, BUT, the local NBC affiliate is not listed on either side of the channel matching screen, so it is not available to watch. It is a low power station at 1000kw; however I am only 11.1 miles from the tower. I am able to watch the station when the antenna is connected directly to the Fire TV. I have also tried to add a source like Direct TV, but the station still does not appear. I have tried changing zip codes with no avail. Does anyone know how to add a missing local OTA channel? Thanks in advance.
