Yesterday I noticed that many of my shows were not recording. I found that when I checked the DVR many channels were not mapped correctly. I’ve tried deleting the HDHomerun, refreshing channels, updating hdhr firmware, refreshing epg, turning on enhanced program guide and updating plex to the latest version. Also this is happening on two different systems in two different locations. One is running CentOS 7 the other macOS Sierra. See image below.
BTW the channels can be played from the HDHR app without issue.
Checked the channels over 804 and they play fine, plus the guide from HDHR is correct.
@prophoto I had same problem with latest release, i had to completely delete my dvrs from plex and re-add them to get them fixed under 1.7.1. But I later found another issue where this new mkv format all my recordings were crap blocky pixelated and just generally junk i reverted back to 1.6.1 which does standard ts formats and records are perfect again, not sure why mkv format is so flaky or if its something else but i just told my plex to skip this version and I will try later version when its released.
Note i have 2 hdhomerunprimes connected and until i deleted each one and re-added them they did not find all channels and deleteing each one at a time i did NOT lose any of my schedule recordings. Not sure if this was just luck or they fixed it so you don’t lose your scheduled recording like it says you will or not but. thats how I fixed my issue.
Tried deleting and adding back in, didn’t make difference in either location.
Mysteriously removing and adding my HDHR back in today fixed it on one location, checking the other. I spend 6 hours on this yesterday which tells me that someone screwed the pooch and fixed their blunder today. Hopefully someone at Plex or whoever is responsible will own up to their mistake.
Why oh why will no one from the Plex team not comment on this? Clearly multiple people are having issues here. Just for sanity sake it would be nice to get an acknowledgment.
Just adding my “me too” to this thread as I’ve done in a few other threads. This is annoying… I have to delete and add my tuners back in every few days. Fix please!!
Today all my missing channels re-appeared. Seems that when this happens, you have to wait a few days and then they just start re-appearing.
So far there are still there with no issues, I still say someone at Plex screwed up.
