Missing channels in under DVR settings
After upgrading to the latest version of Plex, Version 1.16.1.1291 I noticed that none of my DVR shows were recording. I went into the Live TV & DVR and then into channels and I noticed almost all of the channels had no match in the drop down. I tried rescanning but I have the same problem.
I am using a HDHomeRun Prime and if I use their software, I can access all those missing channels. Plex seems to have the issue. I tried deleting and re-adding the DVR but it did not help.
Is there a bug in this version? If so, what build should I go back to so I can get this working again?
Thanks!
Does anyone from Plex monitor these forums?
Plex removed EPG data for some countries. Is that what you mean? There is no program guide data?
I am in the USA so that did not impact me. The problem is all my channels are now missing, so none of my shows can record.
I am using a HDHomeRun Prime and if I use their software, I can access all those missing channels. I can even go through the browser to the HDHome Run device and these channels so. Plex is just not picking them up.
Same issue for me. Once I installed the 1402 update, live TV was broken and could not watch anything. Searching the forums, I found a “fix” to downgrade 1226 which allowed me to watch live TV but the guide is partially working and the recording scheduled is complete empty now.
I’m not sure why Plex as a company can’t at least address this and provide fix. I’ve been pleased with Plex till now.
