Recordings failling and can't watch certain channels
For a few weeks, about half of my recordings are not recording and I don’t even get an error in the recordings section. The thing is before that is was working.(I’m using the BETA channel, but I had the same problem before switching)
I’m using two HDHomeRun tuner(A CONNECT and a CONNECT Quatro).
Some of the channels work fine and others just don’t work at all.(Unable to tune channel (No parts), but I can watch those channel directly with vlc if I want, just not with plex.
Also it looks like the recordings are done on the wrong tuner. For example, I have two channel on my CONNECT and 3 on the Quatro and I got a conflict saying that I got too many recordings at the same time and that should be impossible.
I tried restarting plex, deleting and adding back both device, but nothing seems to work, and it’s annoying, because a lot of TV show aren’t recorded.
Similar issue : 2 HDHomeRun units (4 tuners) Different channels enabled. Plex DVR tries to record from wrong tuner and Plex DVR, Trying to watch Live TV but get error "Unable to tune channel (no parts)"
