Missing Metadata After DVR Recording
First, I don’t work or speak for Plex, just a long time user and reader of these forums.
This thread is marked solved so it is unlikely to get any more attention.
The answer was pretty complete, in order to make recordings from the EPG more reliable they are only using the info from the EPG.
Plex doesn’t comment on possible and future development. If they are working on automatic replacement of metadata from the scanner after recording you won’t know till it is released.
Hi Tiebierius,
I’m glad you wrote to me, I always thought EPG meant that’s what Plex meant and I only use it. That’s why I don’t understand why it’s not going right?
Or does EPG mean something else, if so, what exactly?
For me, it’s just that only a few meta-data is adapted. What makes me the most
It’s annoying that age is missing because of my children!
If, however, this remains the case at the moment, I will have to act in this way until further notice.
Another completely different question can the cutting of advertising be improved somehow?
Thank you very much for your prompt reply
Kind regards
Smarti75
Electronic Program Guide (EPG) detail is provided to Plex by Gracenote. The detail of info that Gracenote receives is from the Broadcaster. Seems your broadcaster is giving abbreviated descriptions leaving you to do an update to pull from your chosen source.
Hi Tiebierius,
Unfortunately, I don’t quite understand what you mean, I have a “VBox Android TV Gateway
XTi 4144” with 4 tuners. I don’t use the EPG from the box because it’s not complete.
That’s why I use the EPG from PLEX Server, but this information is not complete too. Than I have to rework this Movie Manuel. I wanted know is’it normal or I doing something wrong? It’s a movie and not a series, so I couldn’t do anything with the previous information, Ithink so.
Or is this not supported so far? As a reply to “drzoidberg33” I wrote back, he no longer replied to my post. Sorry, I findet not so good, that he not wrote back to me. Than can you tell me that the System are not so far to do that.
Maybe you can give me more detailed information if the Plex can’t!
Aufnahme 720p
Kind regards
Smarti75
Hi Tiebierius,
I correctet my mistakes in the Contribution over this one.
I Translated with my Apple from German in English, that was a fault.
Because the translater wrote something wrong and some words are was very badly.
I’m sorry for that !
Kind regards
Smarti75
Hello everyone,
I wanted to ask if something is being done about it or not?
Would actually be nice, unfortunately you suddenly don’t get an answer anymore?
Kind regards
Smarti75
Hello everyone,
I dont know why it’s closed, then the Problem still are here!
Kind regards
Smarti75
