Tidal Integration - Compounding Issues
To summarise the major issues currently besetting Plex Tidal integration:
  1. New releases available directly from Tidal are not available via Plex until after some delay - and this delay appears to be increasing
  2. Plex surfaces releases that are not available directly from Tidal
  3. Plex fails to surface releases that are available directly from Tidal
These issues severly diminish the usefulness of the integration.
Edit: Note that Sonos Tidal integration does not suffer from these issues.
Adding my voice having now experienced ALL these issues. Hoping we actually get a response.
thanks for compiling our topics. Also would like to point out that there is an album I’ve been waiting for since “03-06-2021” that still hasn’t showed up in plex
Can you mention which album you’ve been waiting on?
Sure, it’s Iliya Ryakhovskiy - The Age of Calamitous
The album I was waiting for when I made my original topic was ENHYPEN - BORDER:CARNIVAL wich eventually showed up after a couple of weeks
It’s hard for me to believe that there is something wrong with individual tracks or albums in Tidal that are causing them to not appear in Plex. It seems more likely that there is a systemic problem. In any case, this album is in Tidal but I can’t see it in Plex: Victor Gould In Our Time, In Our Time by Victor Gould on TIDAL .
Just to add to this thread, I have another issue with Tidal that may also be affecting the issues shown above. As I’ve explained in “Tidal integration picking up wrong album data”, an album I can view on Tidal is incorrectly identified when viewed in Plex and has the wrong narrative text and omits five tracks as a consequence. There is no way to “Fix match” like there is with library files, so it’ impossible to play the whole album via plex.
The same artist I made a thread for before has released another album on TIDAL and yet again it’s not showing up in Plex : TIDAL
Put it in a playlist on tidal - the playlist shows up in plex - shows correct running time and album cover collage thingy - doesnt have any tracks inside
