Missing posters on ONE ATV
Hi all,
I have an interesting problem with one of my ATVs.
I recently needed to re-install Plex and PlexConnect due to a drive crash, so I setup Plex, then Plexconnect and loaded a new cert on my ATVs.  One ATV works perfectly, the other shows no posters or other images in any library or media view, it also cannot play content.
I have fully reset the non-working ATV back to default, upgraded firmware and factory reset, then loaded the cert via the http://trailers.apple.com/trailers.cer, still no posters.
I have an iPhone with Plex that works perfectly, and XBox and 1 ATV, but this second ATV is quite stubborn.
Ive attached my PlexConnect log to see if anyone can gather anything.
Plex is running on Windows 7 and as noted I have no issues with any other device.
Attached is my Plexconnect log to see if it has any clues.
Dean
Well that was strange, I fixed it by changing the IP address of the offending ATV unit from DHCP to manual and changing the IP from 106 to 136. :|
Hope this helps someone else
