Missing Server Settings
Server Version 1.18.9.2578-513b381af-x86 on Synology NAS
I logout from connected-server via browser.
NOW:
From this time i can not reconnect to the plex- server.
My complete Media dispappear.
No Server Settings available.
No Server Settings Option available.
I tried to link to an old server settings url
!/settings/server/8dbc0719524c125a1d95a82aa9e6bf9552a1728a/status/server-dashboard
I get 401 unauthorized
Restart the server has no effects.
Reinstall the server has no effects.
I try to reconnect via plex.tv
No effects.
Plexf-Web shows all the time i should install a server?!?
Server is running but I can not connect to the server.
Need Support.
You might want/need to check this support article… sounds like you locked yourself out
Thanks a lot for your response.
I Stop the plex-server
I delete all the key/value pairs as descripted from preferences.xm
I start again the plex-server
I open the weburl and get the redirect to https://app.plex.tv/auth/#!?clientID=
I login
But
still the server is missing and all my media etc.
don’t go through app.plex.tv – you need to directly go to the local PMS -> http://[PMS IP address]:32400/web
YES, yes, yes yes it works now thanks a lot.
i typed at first my fulldns not the ip.address.
thanks a lot
my media files, lists, etc. are back
