Missing some entries in "new" agents
Dear Team,
I am missing two entries in the new Plex Movies & Series agent:
  • Movies: imdb-tt0346293
  • Series: tvdb-26804
Can both entries please be added?
That’s a mini series and will only match in a “Series”-type of library.
That’s not a series but a movie, so it won’t match in a “Series”-type of library.
Hi Otto,
I have just checked directly from the database and with the old agents, I was able to match both:
  • com.plexapp.agents.imdb://tt0346293?lang=de
  • com.plexapp.agents.thetvdb://270371?lang=de
For the series, yes you are right, sorry I did a mistake - I selected the wrong ID :confused: but I am also not able to match it with this one anymore.
That is a movie as well.
But it doesn’t look like it has an age rating on any of the metadata sites.
That sometimes prevents it from getting matched.
See if you can match it with the new agent, by putting tmdb-264413 into the Title field under Search Options.
