Tried Mixes for You on both the Android and Windows and when I select a mix and click on download nothing happens. Version 4.8.2
Settings → Device → Debugging → Share Logs → Save To Files
Upload .Zip file using the Upload icon on the post toolbar.
27927755791752.zip (234.5 KB)
Looking at the logs, it seems like 42 tracks downloaded. What does your downloads tab show?
Nothing other than what was already there. When I select download I don’t even get the popup slider to select how many hours.
That might be because it’s under a certain amount. If that’s the case it just downloads it all.
Is it possible you have one Mix for You downloaded and you’re trying to download a second?
It’s not downloading. I never had an issue with this before. Doesn’t matter what suggested artist shows I have tried several different ones and they don’t download.
- Kill the app.
- Restart the app.
- Select download on a Mix for You.
- Wait for a minute or so.
- Upload the Plexamp logs.
40447758079400.zip (288.2 KB)
Thanks very much for your patience, I’ve verified it’s an issue, will be fixed in the next release.
Thanks Elan, greatly appreciated.
