.mkv converted to MP3 TV series not showing up in FetchTV
Hi all
Movies I have with the .mkv file format I can stream to my FETCH TV I can view but my TV series with the mkv format are not visible, I have converted them to MP4 but still not visible is the a PLEX thing or some thing else that I have missed.
Cheers
MP4 is slightly more compatible for playback on some devices, but both MP4 and MKV should be visible in the Plex library. My first guess is that your problem isn’t the container.
Have you followed the media naming guide?
  • /TV Shows/ShowName/Season 02/ShowName – s02e17 – Optional_Info.ext
Can you share some additional information?
What directory is your library pointing to?
What is the structure of your media library, the folders that contain shows, seasons, and the names of your files themselves?
Screenshots would be ideal.
Hello Volts
Thanks for sending the link , Naming and Organizing Your TV Show Files I just had every movies and TV shows in the same folder and that was the problem.
Fixed now.
