There seems to be a problem when I play A .MKV video file on my computer using Plex Media server at the end of the program it seems to be looking for something and doesn’t return to your menu.
If I convert it to a MP4 there is no problem
This happens when it wants to switch to the next video in the seasons of shows after converting to MP4 it moves to the next version
This has been a problem tor the last few versions.
Steve
anyone else having the same problem.
Steve
Which OS are you using Steve?
I am using Windows 10 up to date
Ok,
read threw the following discussions there maybe answer for you.
Then again click on the Eclipse (…) in the "series Poster’s right hand corner and select “Play All” maybe that will help.
Cheers
