Does Plex keep changing their matching for season 3 of this show? Scanner and Agent both are set to Plex’s. It scans it properly.. shows up as season 3.. but randomly it will disappear. I have no clue why. The naming and files are NOT changing. If I trigger a library scan it pops back into Plex again.
This might give some context.
If I read the thread correctly, setting the episode ordering for the show should allow getting it matched as a single show. The show appears to be split in 2 on TMDb (or it at least used to); so if Plex defaults to the TMDb episode ordering, that’ll give you trouble.
Same issues here with seasons 1 & 2. Both showed up as season 1. For season 2 I had to go in and add my own artwork and put in the episode titles myself. For some reason the series just confuses the hell out of the match database.
This show and it’s anthology series is a mess in plex if you use tmdb episode ordering. Your only option really is to use tvdb episode ordering.
