More Transcode Options for?
Server Version# 4.121.1:
Player Version# 4.121.1 (app.plex.tv)
Tuner Make/Model: HDHomeRun Connect Duo
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Currently, when streaming a 720p channel, the transcode options seem to max out at 4mbps quality and original. Unfortunately, my server doesn’t have enough upload bandwidth to handle the original quality stream, but I would like a higher quality option than the 4mbps (noticeable compression artifacts when watching football).
Would it be possible to get an ultra 720p option that uses 6mbps or 8mbps?
Thanks!
Screenshot 2024-01-05 at 9.33.36 AM
Click the Show All.
Clicking “Show all” does not change the options available
Could it be that the original OTA channel isn’t streaming above 4 Mbps and so Plex doesn’t allow you to set a higher option?
I’ve got some local subchannels channels that don’t go above 4.
