Yesterday, my TV Shows “Recommended” disappeared out of nowhere, which also made it no longer appear on my Home ribbon on all platforms (browser, Smart TV, Android).
Then today, after the update, all libraries except music have disappeared. I always get “Something Went Wrong. An unexpected error occurred.”
I’ve found the location but I can’t figure out how to give myself permission to the appdata file in windows to be able to copy them and delete/rename the appropriate files.
The Appdata directory is owned by root on Unraid. You would need to enable the SMB share and set write access for your user.
Navigate to Settings -> Users and create a user to grant read/write access for (skip this step if you have one already)
Navigate to Shares -> appdata
Under SMB Security Settings
set Export = yes
set Security = private
Under SMB User Access
set your “user” to Read/Write
On your Windows computer, connect to your server and when you click on appdata share it should prompt you for a user/password. Use the user you setup. This should now give you the ability to change the files in appdata.
