Hello,
I need help. I can’t mount OneDrive using rclone on my linux vps server
How did you guys do that?
Problem:
RClone works fine. After I mount Onedrive in the shell, Plex can’t see the Onedrive files, with ftp I see the files.
Problem:
I don’t know how I mount OneDrive using rclone at server startup.
Greetings
For problem 1:
Which user are you mounting as?
check /etc/fuse.conf and make sure you have this line in it:
user_allow_other
and maybe try adding --allow-other to your mount command
I am using this guide:
I login in the ssh with my “username” and mounted OneDrive in a folder, named onedrive.
I add “user_allow_other” in fuse.conf. Still cant see the Onedrive files in the folder onedrive.
ok, so from the example there:
rclone --vfs-cache-mode writes mount onedrive: ~/OneDrive
does it make any difference if you try this:
rclone --allow-other --vfs-cache-mode writes mount onedrive: ~/OneDrive
the command does not work:
Error: unknown command “writes” for “rclone”
Run ‘rclone --help’ for usage.
2019/10/06 19:56:05 Fatal error: unknown command “writes” for “rclone”
ok, that’s bit odd as that is pretty much what I use, so what about this one:
rclone mount onedrive: ~/OneDrive --allow-other --vfs-cache-mode writes
system
Closed
7
