Mouse control macOS Desktop Client
Server Version#: Version 1.29.2.6364
Player Version#: Version 1.58.1.3380-ea159c52
I run the desktop client on my Mac mini in a multi-screen setup, and find it really annoying that to shift focus to the app I have to either command+tab to it or click the icon on the dock, then move the mouse to the screen and select subtitles, or whatever, because if I touch the screen with a mouse pointer whatever is playing stops.
It would be great if you could select the ability of the mouse click to not be a media control, but still a UI control.
That being said, that is the only issue I have with the latest iteration. I’ve been using Plex for years and it’s just such a solid and reliable platform.
To those that did that, thanks.
