How can I move metadata from a Linux server to a Synology NAS?
tom80H
March 17, 2021, 9:10pm
2
this post from the synology tips & ticks basically applies to your use case as well
FAQ 18: Moving PMS from Mac/Windows to Synology
Note: This method mimmicks the “DSM 7 ‘migration’”. It is done this way to maximize automation and ensure a successful import.
Make certain to turn off / disable the following in Plex Settings > Server > Library before stopping PMS.
a. Scan my library automatically
b. Run a partial scan when changes are detected
c. Scan my library periodically
d. Empty trash automatically after every scan
Stop PMS on the source (Mac/Windows) machin…
If i may augment?
On Linux, there’s quite a shortcut which can be taken if you are comfortable enough.
This is the prep side before carrying to DSM.
Backing up your PMS data involves the same steps you’ll need if you were to clone your PMS and take to a new computer, reinstall the operating system, or just want a backup for safe keeping.
Stop PMS
Invoke the root shell
Create the backup image
[chuck@lizum ~.74]$ sudo sh
sh-4.4# cd /var/lib/plexmediaserver
sh-4.4# tar cfz /nas/tmp/PlexBackup.tar.gz ./Library
sh-4.4# ls -la /nas/tmp/PlexBackup.tar.gz
-rw-r--r--. 1 root root 864050144 Oct 29 15:29 /nas/tmp/PlexBackup.tar.gz
sh-4.4#
Copy …
On Synology, you use FileStation to change the owner (UID) for best results.
You want user plex to own the media – FileStation will show you the correct name.
system
Closed
June 16, 2021, 3:37am
4
