Movie information not always loading
I run PMS on my Nvidia Shield and my data libraries are stored on a (Qnap) NAS.
Recently I’ve reset my Shield and set everything up again.
At first everything seemed fine, however after restarting the Shield I started to have issues.
Movie information doesn’t always load and seems to time out. Once a particular movie has loaded (and cached?) the information, it works.
However new movie information doesn’t always work, it’ll show the cover and title and the plex yellow spinning circle.
Then it’ll display an error: “Something Went Wrong - It looks like something went wrong. Please try again.” With an picture of the TV (player) being disconnected from the PMS/Storage.
If I keep trying, the information will eventually load, but a next movie will have the same problems.
I’ve also tried with an other Plex player (app) and that has the same issues.
Using the web player seems to work fine.
Also Shows seem to work with both apps and web.
I’ve already reset the Shield, set everything up again and on first boot all seems well, but after restart I start having problems.
As a test, I’ve set up PMS on a pc, that seems to work fine.
Info and log below:
Server Version#: 1.21.1.3830
Player Version#: 8.11.0.22186
Jan 02, 2021 17:07:47.267 [6954] Debug — Auth: authenticated user 1 as LangeName
Jan 02, 2021 17:07:47.267 [14302] Debug — Request: [192.168.49.1:43748 (Subnet)] GET /library/sections/1/all?includeCollections=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&sort=titleSort&type=1 (13 live) TLS Page 72-95 GZIP Signed-in Token (LangeName)
Jan 02, 2021 17:07:47.269 [14302] Error — Unknown metadata type: folder
Jan 02, 2021 17:07:47.269 [14302] Debug — Setting container serialization range to [72, 95] (total=-1)
Jan 02, 2021 17:07:47.285 [14302] Debug — Setting container serialization range to [72, 95] (total=436)
Jan 02, 2021 17:07:47.297 [6955] Debug — Completed: [192.168.49.1:43748] 200 GET /library/sections/1/all?includeCollections=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&sort=titleSort&type=1 (13 live) TLS GZIP Page 72-95 29ms 11175 bytes (pipelined: 5)
Jan 02, 2021 17:07:54.168 [6954] Debug — Auth: authenticated user 1 as LangeName
Jan 02, 2021 17:07:54.168 [14302] Debug — Request: [192.168.49.1:43748 (Subnet)] GET /library/metadata/834?asyncAugmentMetadata=1&checkFiles=1&includeExtras=1&includeReviews=1 (13 live) TLS GZIP Signed-in Token (LangeName)
Jan 02, 2021 17:07:54.180 [14500] Debug — Augment: Deleting 0 expired augmentations.
Jan 02, 2021 17:07:54.183 [6955] Debug — Auth: authenticated user 1 as LangeName
Jan 02, 2021 17:07:54.183 [14973] Debug — Request: [192.168.49.1:43760 (Subnet)] GET /photo/:/transcode?background=000000&blur=0&format=jpeg&height=1080&opacity=80&quality=90&url=http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F834%2Fart%2F1609550300&width=1920 (14 live) TLS GZIP Signed-in Token (LangeName)
Jan 02, 2021 17:07:54.183 [14973] Debug — [Transcode] Photo transcoder: Request for url [http://127.0.0.1:32400/library/metadata/834/art/1609550300] (is local: 1 upscaled: 0)
Jan 02, 2021 17:07:54.184 [14973] Debug — [Transcode] Auth: authenticated user 1 as LangeName
Jan 02, 2021 17:07:54.185 [6954] Debug — Completed: [192.168.111.100:61983] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (14 live) TLS GZIP 20003ms 5 bytes (pipelined: 1)
Jan 02, 2021 17:07:54.190 [14973] Debug — [Transcode] Calculated media file path for path [metadata://art/9ea0fd3627c46c933c8e3756a6954530c0c29131]: ["/data/user/0/com.plexapp.mediaserver.smb/Plex Media Server/Metadata/Movies/b/9db72c577ed35f0b0d34dba362180244da1c9d6.bundle/Contents/_combined/art/9ea0fd3627c46c933c8e3756a6954530c0c29131"]
Jan 02, 2021 17:07:54.191 [6955] Debug — Auth: authenticated user 1 as LangeName
Jan 02, 2021 17:07:54.192 [14980] Debug — Request: [192.168.111.100:61985 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (13 live) TLS GZIP Signed-in Token (LangeName)
Jan 02, 2021 17:07:54.193 [14980] Debug — Content-Length is -1 (of total: -1).
Jan 02, 2021 17:07:54.196 [14973] Debug — [Transcode] Calling back into ourselves for photo to transcode, optimizing the process (status: -1)
Jan 02, 2021 17:07:54.246 [14984] Debug — Media Analyzer: Performing on-the-fly analysis on 1 item.
Jan 02, 2021 17:07:54.246 [14984] Debug — Job running: EAE_ROOT=’/data/user/0/com.plexapp.mediaserver.smb/cache/pms-53a44bc4-f517-48cc-8f56-d13a50303558/EasyAudioEncoder’ FFMPEG_EXTERNAL_LIBS=’/data/user/0/com.plexapp.mediaserver.smb/Plex\ Media\ Server/Codecs/367b3d4-3654-android-aarch64/’ X_PLEX_TOKEN=‘xxxxxxxxxxxxxxxxxxxx’ ‘/data/user/0/com.plexapp.mediaserver.smb/Resources/Plex Media Scanner’ ‘–analyze’ ‘–log-file-suffix’ ’ Analysis’ ‘–item’ ‘834’
Jan 02, 2021 17:07:54.246 [14984] Debug — Jobs: Starting child process with pid 14985
Jan 02, 2021 17:07:54.247 [6954] Debug — Auth: authenticated user 1 as LangeName
Jan 02, 2021 17:07:54.247 [14980] Debug — Request: [192.168.49.1:43762 (Subnet)] GET /photo/:/transcode?height=600&quality=90&url=http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F834%2Fthumb%2F1609550300&width=400 (14 live) TLS GZIP Signed-in Token (LangeName)
Jan 02, 2021 17:07:54.247 [14980] Debug — [Transcode] Photo transcoder: Request for url [http://127.0.0.1:32400/library/metadata/834/thumb/1609550300] (is local: 1 upscaled: 0)
Jan 02, 2021 17:07:54.248 [14980] Debug — [Transcode] The cache file did not exist, but the original did [/storage/emulated/0/Android/data/com.plexapp.mediaserver.smb/cache/PhotoTranscoder/91/9107c9c1471ca0696c0dd96473a5425ebf95c987.jpg].
Jan 02, 2021 17:07:54.268 [14973] Debug — [Transcode] Photo cache obtained 344288 bytes from http://127.0.0.1:32400/library/metadata/834/art/1609550300
Jan 02, 2021 17:07:54.268 [14973] Debug — [Transcode] Saving original media file to /storage/emulated/0/Android/data/com.plexapp.mediaserver.smb/cache/PhotoTranscoder/10/10493ab8317f2f11822b23f86d09bdfa9e20f594.jpg
Jan 02, 2021 17:07:54.345 [14973] Debug — [Transcode] Created thumbnail of size 1920x1080, has pixels: 1
Jan 02, 2021 17:07:54.384 [14980] Debug — [Transcode] Created thumbnail of size 400x600, has pixels: 1
Jan 02, 2021 17:07:54.417 [14973] Debug — [Transcode] Converted 32-bit thumbnail of type 1 to 24-bit with pixels
Jan 02, 2021 17:07:54.427 [6954] Debug — Completed: [192.168.49.1:43762] 200 GET /photo/:/transcode?height=600&quality=90&url=http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F834%2Fthumb%2F1609550300&width=400 (14 live) TLS GZIP 180ms 108967 bytes (pipelined: 1)
Jan 02, 2021 17:07:54.667 [6954] Debug — Completed: [192.168.49.1:43760] 200 GET /photo/:/transcode?background=000000&blur=0&format=jpeg&height=1080&opacity=80&quality=90&url=http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F834%2Fart%2F1609550300&width=1920 (14 live) TLS GZIP 483ms 493109 bytes (pipelined: 1)
Jan 02, 2021 17:08:14.194 [6955] Debug — Completed: [192.168.111.100:61985] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (9 live) TLS GZIP 20002ms 5 bytes (pipelined: 3)
Jan 02, 2021 17:08:14.205 [6955] Debug — Auth: authenticated user 1 as LangeName
Jan 02, 2021 17:08:14.206 [14990] Debug — Request: [192.168.111.100:61999 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (9 live) TLS GZIP Signed-in Token (LangeName)
Jan 02, 2021 17:08:14.207 [14990] Debug — Content-Length is -1 (of total: -1).
Jan 02, 2021 17:08:24.246 [14984] Debug — Killing job.
Jan 02, 2021 17:08:24.246 [14984] Debug — Signalling job ID 14985 with 9
Jan 02, 2021 17:08:24.247 [14984] Debug — Media Analyzer: Background analysis completed in 30.0 seconds, removing 1 IDs
Jan 02, 2021 17:08:24.263 [14302] Warning — SLOW QUERY: It took 960.000000 ms to retrieve 71 items.
Jan 02, 2021 17:08:24.263 [6709] Debug — Jobs: ‘/data/user/0/com.plexapp.mediaserver.smb/Resources/Plex Media Scanner’ exit code for process 14985 is -9 (signal: Killed)
Jan 02, 2021 17:08:24.265 [14302] Debug — We’re going to try to auto-select an audio stream for account 1.
Jan 02, 2021 17:08:24.265 [14302] Debug — Selecting best audio stream for part ID 2015 (autoselect: 1 language: en)
Jan 02, 2021 17:08:24.265 [14302] Debug — We’re going to try to auto-select a subtitle.
Jan 02, 2021 17:08:24.265 [14302] Debug — Subtitles: Found a candidate subtitle language [eng] for a foreign film
Jan 02, 2021 17:08:24.265 [14302] Debug — Audio Stream: 4255, Subtitle Stream: 4255
Jan 02, 2021 17:08:24.346 [14302] Debug — Activity: registered new activity d505e371-77f5-42d5-a8d7-d900eee8c016 - Refreshing
Jan 02, 2021 17:08:24.346 [14279] Debug — Activity: updated activity d505e371-77f5-42d5-a8d7-d900eee8c016 - completed 0.0% - Refreshing
Jan 02, 2021 17:08:24.349 [6954] Debug — Completed: [192.168.49.1:43748] 200 GET /library/metadata/834?asyncAugmentMetadata=1&checkFiles=1&includeExtras=1&includeReviews=1 (7 live) TLS GZIP 30181ms 7785 bytes (pipelined: 6)
Jan 02, 2021 17:08:25.175 [14992] Debug — Augment: Found a provider match for ‘MOVIETITLE’.
Jan 02, 2021 17:08:25.175 [14992] Error — Unknown metadata type: mixed
Jan 02, 2021 17:08:25.175 [14992] Debug — Augment: Completed movie augmentation in 0.8 sec.
Jan 02, 2021 17:08:25.175 [14279] Debug — Activity: Ended activity d505e371-77f5-42d5-a8d7-d900eee8c016.
Jan 02, 2021 17:08:34.208 [6954] Debug — Completed: [192.168.111.100:61999] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (6 live) TLS GZIP 20002ms 5 bytes (pipelined: 1)
Jan 02, 2021 17:08:34.221 [6954] Debug — Auth: authenticated user 1 as LangeName
Jan 02, 2021 17:08:34.221 [14302] Debug — Request: [192.168.111.100:62001 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (6 live) TLS GZIP Signed-in Token (LangeName)
Jan 02, 2021 17:08:34.222 [14302] Debug — Content-Length is -1 (of total: -1).
Any help would be much appreciated.
Posting excerpts from log files isn’t a viable debug method.
  1. Recreate & capture the error.
  2. Attach the ZIP file it gives you here, in its entirety.
HI ChuckPa,
Thanks for your reply.
I checked the time when I opened the movie information and it generated the error and copy/pasted the log from that point.
That’s all the info in the log.
Do I restart PMS and provide a full log from the start?
Please do.
Snippets, in the forum format, miss so much info and are impossible to really see what’s happening. Often, what we need occurred about 30-40 lines before (which you wouldn’t know unless you knew what to look for)
