Movie Posters not downloading on recently migrated Synology
I recently upgraded my Synology from DS216play to DS918+. The migration went well and I reinstalled Plex over the old installation (v1.13.3.5223). Everything looked ok, until I added some new movies when I discovered the posters were not downloading for the new items. I tried a few things, like deleting the caches and running “Refresh All Metadata” on the “Movie” library (based on other threads I saw about this), but it didn’t seem to help. I figured I would start over completely, so uninstalled and deleted all of the files under “Plex/Library”, reinstalled, but ran into the same issue once the Movies directory was parsed!
Also, the “TV Shows” and “Music” poster and metadata is perfectly fine.
Any ideas on what is happening here?
Thanks, Allen
I think I did the Plex Dance ok, but it didn’t seem to help… I did end up deleting the newly added media just in case that was it, as part of the dance, but like I said, no change in the library.
Attached are the logs.
Plex Media Server Logs_2018-07-01_21-54-44.zip (5.1 MB)
When I moved over to the new NAS, I did enable the firewall, which I thought was on before and was lost in the transfer, but it must not have been active before the migration since that was the issue.
With that said, I disabled it and tried the Dance again with no success, so I simply reinstalled again, and it everything worked as expected on the new installation.
I do still have a question about the Dance though… What is the “Update Library” step exactly? Everything other step seemed straight forward but I see no “Update Library” option anywhere.
Thank you for all your help.
Ah, ok. Thanks for the clarification and thank you again for the help fixing this issue.
