I have a humble plex server that I 'm running with about 400 movies on it. No problems until about 2 weeks ago. Currently, I only have a some of my movies that show posters or metadata where as before all movies would show just fine. Here is what I’ve done so far:
Forced update of all metadata on the movies library
Repaired the Plex install
Completely uninstalled Plex (including Registry and AppData files) and reinstalled (new database) on new drive
Cleared HTTP cache and log files
Still having issues with movie metadata not showing up. One last weird thing. If I select a movie that has no metadata and ‘unmatch’ it, the poster and metadata sometimes appears!
And all of your media is named and structured exactly as required per the Plex naming requirements? Please provide exact examples for a few movies that don’t match.
/Movies
/Avatar (2009)
Avatar (2009).mkv
/Batman Begins (2005)
Batman Begins (2005).mp4
Batman Begins (2005).eng.srt
Also, your media files, might have some metadata stored in them that could be causing issues (metadata entered incorrectly). Check to see how they are tagged and remove the metadata from the media file, then try and rescan and see if it picks up.
I have also been experiencing this problem for a number of weeks now. While I have not determined the cause or solution, I can assure you that in my case it is not the files, their naming, directory structure, or any embedded metadata. Something else is up.
Still experiencing this problem, @oyehia ? I certainly am. Among the 72 most-recently-added Movies in my library, this situation continues to plague 43 of them. It’s pretty much to be expected at this point that the Movies library will look like ■■■■ going forward.
