Good day forum participants Plex!
Please advise me, faced with such a problem that the name of the movies steel to be written in small letters. I manually change the capital letter after updating the metadata and still return the name to a small font. What could be? Who the rebuffed?
In the directory all movies are named with a capital letter as it should be.
Pretty sure it’s this: Some episodes do not have good titles
Thanks for the reply and another question, the movie should be in English named directory or in a different language to podpisati?
If it is a mp4 file, Plex might use the name from the files metadata, instead of using the name it gets from IMDB etc. If that is the case you have to tell it to use data from the internet before it looks at local data. If that is that is the case, then you can go to Settings-Agents, Movies. In the “Plex Movie” and The Movie Database" setting you have to drag “Local Media Assets” down one spot so that it isn’t on top. Another option is to remux the mp4 file to mkv, but that might be way more hassle if you have many files.
Yes movies very much, decided to do everything in folders as described above in the subject. Couple of files changed correctly renamed and everything turned out, all thanks for consultation and for the help in the solution of this question!
