movie transcoding problem? (picture attached)
Any ideas of what causes this? The server CPU doesn’t seem to be close to maxing out at all. Windows, i7, I only noticed this during high activity / fast moving scenes blurays. “Slow” scenes are fine.
Perhaps some settings aren’t setup properly? I’ve used it for a year and just now started doing full size file blu ray .mkv files
Any ideas are welcomed.
The picture doesn’t really show us what the server is trying to do. Can you get the log files for the timeframe that this is happening? Might also help to have the xml info for the media, as well.
Just a guess, but if you are doing a transcode, you could be using only one core of the CPU for transcoding and it may not be able to handle the heavy action scenes.
