vraag,
Ik zit met een probleem, namelijk dat alle films die ik in plex heb staan enorm langzaam starten.
Dit betref via OpenPHT en Rasplex. via PlexWeb gaat het wat sneller…
Ik heb geprobeerd: Direct-play, Geforceerd Transcode, zonder ondertiteling, Plex restart en server restart.
Dit probleem betreft alleen de movies, series en andere bibliotheken laden gewoon zoals ik gewent ben…
Wat kan dit zijn???
Dit kwam ik tegen in 't logboek: (en dit ~~~~maal 3x achterelkaar, terwijl ik op dat moment 1 ding aan het laden was):
Sep 29, 2016 21:28:32.544 [0x2b675da06700] DEBUG - Request: [192.168.1.48:49859 (Subnet)] GET /library/streams/496857?encoding=utf-8 (6 live) TLS Signed-in Token ('USER')
Sep 29, 2016 21:28:32.724 [0x2b675da06700] DEBUG - It took 180.000000 ms to retrieve 1 items.
Sep 29, 2016 21:28:32.819 [0x2b675da06700] DEBUG - It took 90.000000 ms to retrieve 1 items.
Sep 29, 2016 21:28:32.823 [0x2b675da06700] DEBUG - Detected character set of UTF-8.
Sep 29, 2016 21:28:32.827 [0x2b6744e00700] DEBUG - Completed: [192.168.1.48:49859] 206 GET /library/streams/496857?encoding=utf-8 (6 live) TLS 283ms 58901 bytes (pipelined: 1046)
Sep 29, 2016 21:28:32.836 [0x2b6745001700] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Sep 29, 2016 21:28:32.836 [0x2b6745001700] DEBUG - Auth: authenticated user '0000' as 'USER'
Sep 29, 2016 21:28:32.837 [0x2b6766202700] DEBUG - Request: [192.168.1.48:49859 (Subnet)] GET /library/streams/539002?encoding=utf-8 (6 live) TLS Signed-in Token ('USER')
Sep 29, 2016 21:28:33.012 [0x2b6766202700] DEBUG - It took 170.000000 ms to retrieve 1 items.
Sep 29, 2016 21:28:33.108 [0x2b6766202700] DEBUG - It took 100.000000 ms to retrieve 1 items.
Sep 29, 2016 21:28:33.113 [0x2b6766202700] DEBUG - Detected character set of UTF-8.
Sep 29, 2016 21:28:33.117 [0x2b6745001700] DEBUG - Completed: [192.168.1.48:49859] 206 GET /library/streams/539002?encoding=utf-8 (6 live) TLS 280ms 76507 bytes (pipelined: 1047)
Sep 29, 2016 21:28:33.130 [0x2b6744e00700] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Sep 29, 2016 21:28:33.130 [0x2b6744e00700] DEBUG - Auth: authenticated user '0000' as 'USER'
Sep 29, 2016 21:28:33.130 [0x2b6752401700] DEBUG - Request: [192.168.1.48:49859 (Subnet)] GET /library/streams/497200?encoding=utf-8 (6 live) TLS Signed-in Token ('USER')
Sep 29, 2016 21:28:33.305 [0x2b6752401700] DEBUG - It took 170.000000 ms to retrieve 1 items
Server spec:
Unraid 6.2, Plex in Docker (linuxserver/plex)
PlexMediaServer 1.1.4.2757 (en de laatste bèta in VM, 2 servers op deze machine/account)
I7-4790, 16GB ram
nope, staat gewoon aan. er is na mijn inzien niks verandert aan de settings. alles staat nog zoals ik het een tijd geleden had ingesteld. zelf de VM met de Bèta staat het zelfde ingesteld.
trouwens, het valt me nu op dat wanneer ik met Plexweb (via Firefox, heb geen andere browser) geregeld bij het laden van film info (daar mee bedoel ik dus het scherm dat je krijgt voordat je wil start) dat firefox gewoon geheel vast loopt en vervolgens meld dat er een script niet mee reageert…
Zal eens kijken of een algehele refresh en analyse van de movie bibliotheek werkt, zo niet, dan zit er denk ik niks anders op dan de gehele bibliotheek te verwijderen en opnieuw aan te maken, dit is dan wel een last try…
firefox heb ik ook 1 bak ellende mee gehad niet om plex gewoon in zijn geheel gebruik het amper meer. Misschien je server even los koppelen van je account en opnieuw koppelen aan je plex account om nieuwe certificaten aan te vragen ? noem even wat geks
dat lijkt me wel een hele gekke oplossing, gezien het probleem zich alleen in de film bibliotheek bevind…
blijkbaar werkt bibliotheek vernieuwen en analyseren niet, ik ga de movie bibliotheek maar eens verwijderen en evt. kijken of ik niet een beginnende database corruptie heb…
Ik neem de tip mee in 't Troubleshooten. Ik ga eerst de movie bibliotheek verwijderen en opnieuw instellen, niet dat ik daar schik van heb… (500+ film staan er in, en niet allemaal werden ze goed herkent of zijn het film die in volgorde horen te staan.)
ja, film series als "the maze runner’ en ‘the divergent series’ en James Bond. Plex/imdb/the movieDB gebruikt alleen de film titel. oftewel al die films staan verspreid door de gehele library. En dan hebben ze ook nog film die verkeerd worden gelezen en dus vergeven worden als een andere film.
Dit houd me dus tegen om de library te verwijderen, kost me weer dagen om dat weer netjes goed te krijgen
nou, bibliotheek verwijdert, Plexweb gaf een pop-up melding dat er problemen waren met het verwijderen van de bibliotheek, kan er niks vinden in de logboeken.
gezien ik over morgen/overmorgen een hardware upgrade ga doen aan de server, ga ik even wachten met het opnieuw toevoegen van de movie library, kan ik ondertussen de logboeken eens even goed door spitten…
nou, bibliotheek toegevoegd. bij het begin even getest. media start snel op en werkte prima. nu een kleine 12u verder. en meer metadata, speelt de media weer niet af!!! wat een schijt zooi.
PlexMediaServer compleet verwijderd en compleet opnieuw begonnen, jammer van de kijk geschiedenis voor zowel de externe kijkers als mij zelf, maar er zijn ergere dingen…
Wat mij opviel; Plex ziet nu veel beter de media. heb nauwelijks zelf de media moeten aanpassen, na genoeg alle films / series worden goed herkent. Muziek is dan wel weer wat minder gezien ik heel wat bundels heb (zoals de Hitzone collecties)
Ook gekeken of films gewoon weer werken zoals het hoort te doen en tot nu toe werkt het prima, hopelijk doet ie het morgen ook nog prima…
Ook denk ik dat ik de oorzaak heb gevonden. Ik heb Plex eerst geïnstalleerd in Docker(Unraid) met de gebruikersID 99:98. dit is dus waarschijnlijk met de upgrade naar Unraid6.2 fout gegaan. Plex staat nu net zoals de rest onder gebruikersID: 99:100
