i found out that i got some trouble with playing movies, TV shows and other media works fine its only my movie library.
when i wanna watch a movie its takes about +/- 10 minutes to play the movie, when its loaded it work fine (can skip forwards/backward/pause)
When start a movie with PlexWeb its start must faster, OpenPHT/rasplex, Plex for Android (the original one from the Playstore) says loading, but thats all, cant cancel it (it hangs, but cant here sound when pressing keys.)
a test direct-play, forced transcoding and check if its has some trouble with subtitles, nothing works…
did en forces refresh, an analyse/optimize database, still trouble…
I don’t know when its started, just found out when i gave a friend access to my server…
this is what i found in the logfiles:
Sep 29, 2016 21:28:32.544 [0x2b675da06700] DEBUG - Request: [192.168.1.48:49859 (Subnet)] GET /library/streams/496857?encoding=utf-8 (6 live) TLS Signed-in Token ('USER')
Sep 29, 2016 21:28:32.724 [0x2b675da06700] DEBUG - It took 180.000000 ms to retrieve 1 items.
Sep 29, 2016 21:28:32.819 [0x2b675da06700] DEBUG - It took 90.000000 ms to retrieve 1 items.
Sep 29, 2016 21:28:32.823 [0x2b675da06700] DEBUG - Detected character set of UTF-8.
Sep 29, 2016 21:28:32.827 [0x2b6744e00700] DEBUG - Completed: [192.168.1.48:49859] 206 GET /library/streams/496857?encoding=utf-8 (6 live) TLS 283ms 58901 bytes (pipelined: 1046)
Sep 29, 2016 21:28:32.836 [0x2b6745001700] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Sep 29, 2016 21:28:32.836 [0x2b6745001700] DEBUG - Auth: authenticated user '0000' as 'USER'
Sep 29, 2016 21:28:32.837 [0x2b6766202700] DEBUG - Request: [192.168.1.48:49859 (Subnet)] GET /library/streams/539002?encoding=utf-8 (6 live) TLS Signed-in Token ('USER')
Sep 29, 2016 21:28:33.012 [0x2b6766202700] DEBUG - It took 170.000000 ms to retrieve 1 items.
Sep 29, 2016 21:28:33.108 [0x2b6766202700] DEBUG - It took 100.000000 ms to retrieve 1 items.
Sep 29, 2016 21:28:33.113 [0x2b6766202700] DEBUG - Detected character set of UTF-8.
Sep 29, 2016 21:28:33.117 [0x2b6745001700] DEBUG - Completed: [192.168.1.48:49859] 206 GET /library/streams/539002?encoding=utf-8 (6 live) TLS 280ms 76507 bytes (pipelined: 1047)
Sep 29, 2016 21:28:33.130 [0x2b6744e00700] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Sep 29, 2016 21:28:33.130 [0x2b6744e00700] DEBUG - Auth: authenticated user '0000' as 'USER'
Sep 29, 2016 21:28:33.130 [0x2b6752401700] DEBUG - Request: [192.168.1.48:49859 (Subnet)] GET /library/streams/497200?encoding=utf-8 (6 live) TLS Signed-in Token ('USER')
Sep 29, 2016 21:28:33.305 [0x2b6752401700] DEBUG - It took 170.000000 ms to retrieve 1 items
Before i gonna remove the library, what can i do else? (i dont wanna lose the watch history, and the library is BIG!)
Server spec:
i7-4790, 16GB RAM
Plex Media Server 1.1.4.2757(plexpass) in docker on Unraid 6.2 (its the linuxserver/plex docker template)
Second Plex Media server DVR beta in VM
