Server Version#: 1.40.4.8679-454562606
Hello good morning,
As you can see in the video, the movies with the {Edition-} tag are not displayed when you select an actor. As you can see, I have the I Am Legend movie with the alternate ending edition and if I go to all the Will Smith movies, that movie does not appear. I have seen that the only way the movie can appear when you select an actor is by removing the tag and re-identifying it. Once that is done, as you can see in the video it already appears in the total movies when you select an actor, but the edition tag has been removed. As you can see, the Alternate Ending tag has been removed and the only way to see the tag again is to remove and re-enter the movie again. But we will have the problem again that the movie does not appear if you go to an actor.
Thanks,
