Mp4's not being added to library
Server Version#: 1.30.0.6486
Player Version#: Plex for LG 3.13.29
I reinstalled my Monterrey OS on my Mac on a new boot drive and reinstalled Plex server as well. Previously Plex found all my mp4 movie files in my local Movie folder and I could watch them no problem. Now it is only finding mkv’s.
I’ve checked permissions and a number of other suggestions I’ve found online but still no luck.
We need logs an/or you provide exact files names of some of the ones that are not being matched. The server does not care if something is an MP4 or an MKV. Only difference in an MP4 is that they can have embedded metadata that can be used in which case they can display as something unexpected.
It’s all Mp4’s and I have a lot of them. Only 41 files are being seen out of hundreds approx.
Here’s a few examples: Lupin - Castle.mp4
The Giant Claw.mp4
I tried moving all the files to a different directory. That made no difference. Initially though, before I did that I tried renaming several files and I got a message saying I couldn’t rename the file with special characters in the title. The new names were just plain text.
I’m attaching a screenshot of my log
BigWheel was referring at the full set of server logs (click link for instructions on how to obtain those; preferably download the logs through the web app and attach the entire zip file).
yeah sorry I forgot to give you link for how to get server logs. That bit in your screenshot is not related to scanning in files.
No worries, here’s the log. thanks for your help.
Plex Media Server Logs_2022-12-13_17-36-22.zip (4.2 MB)
This shows it found that Lupin movie. You don’t see it in your library?
Dec 13, 2022 15:15:23.176 [0x7000097af000] DEBUG - Looking for path match for [/Users/kendallclark/Desktop/Movies 2/Lupin the Third - Castle.mp4]
Dec 13, 2022 15:15:23.608 [0x7000097af000] DEBUG - [MetadataAgent/tv.plex.agents.movie] Found 1 provider matches for 'Lupin the Third Castle (-1)'.
Dec 13, 2022 15:15:23.608 [0x7000097af000] DEBUG - Scanner [Plex Movie]: found cloud match for file '/Users/kendallclark/Desktop/Movies 2/Lupin the Third - Castle.mp4': 'Lupin the Third: The Castle of Cagliostro'
Dec 13, 2022 15:15:23.608 [0x7000097af000] DEBUG - Looking for path match for [/Users/kendallclark/Desktop/Movies 2/Lupin the Third - Castle.mp4]
Dec 13, 2022 15:15:23.609 [0x7000097af000] DEBUG - Added new metadata item (Lupin the Third: The Castle of Cagliostro) with ID 4131
Dec 13, 2022 15:15:24.351 [0x700009f5c000] DEBUG - Loaded metadata for Lupin the Third: The Castle of Cagliostro (ID 4131) in 4ms
Dec 13, 2022 15:15:24.351 [0x700009f5c000] DEBUG - Doing expensive tags write for 'Lupin the Third: The Castle of Cagliostro' because something changed.
Dec 13, 2022 15:15:24.353 [0x700009f5c000] DEBUG - Doing expensive tags write for 'Lupin the Third: The Castle of Cagliostro' because something changed.
Dec 13, 2022 15:15:24.354 [0x700009f5c000] DEBUG - Doing expensive tags write for 'Lupin the Third: The Castle of Cagliostro' because something changed.
Dec 13, 2022 15:15:24.356 [0x700009f5c000] DEBUG - Doing expensive tags write for 'Lupin the Third: The Castle of Cagliostro' because something changed.
Dec 13, 2022 15:15:24.368 [0x700009f5c000] DEBUG - Doing expensive tags write for 'Lupin the Third: The Castle of Cagliostro' because something changed.
Dec 13, 2022 15:15:24.382 [0x700009f5c000] DEBUG - Doing expensive tags write for 'Lupin the Third: The Castle of Cagliostro' because something changed.
Dec 13, 2022 15:15:24.383 [0x700009f5c000] DEBUG - Doing expensive tags write for 'Lupin the Third: The Castle of Cagliostro' because something changed.
Dec 13, 2022 15:15:24.384 [0x700009f5c000] DEBUG - Doing expensive tags write for 'Lupin the Third: The Castle of Cagliostro' because something changed.
Dec 13, 2022 15:15:24.385 [0x700009f5c000] DEBUG - Doing expensive tags write for 'Lupin the Third: The Castle of Cagliostro' because something changed.
Dec 13, 2022 15:15:24.386 [0x700009f5c000] DEBUG - Doing expensive tags write for 'Lupin the Third: The Castle of Cagliostro' because something changed.
Dec 13, 2022 15:15:24.386 [0x700009f5c000] DEBUG - There was a change for metadata item 4131 (Lupin the Third: The Castle of Cagliostro), saving.
Dec 13, 2022 15:15:24.386 [0x700009f5c000] DEBUG - Updating metadata item (save) (Lupin the Third: The Castle of Cagliostro) with ID 4131
yes, I just found that one. I examined the folder a little more closely. I noticed that all the mp4’s that aren’t showing in Plex have “icloud synchronization file” listed for their file type instead of Mp4. I assume I need to change those somehow?
yeah you would need to fix that. I wish i could give you advice on how. Though i am a long time Mac user I’ve never used anything icloud related.
I moved the files to another drive and they work fine. Thanks for your help.
