Multi episodes in single file
Server Version#:1.41.0.2876-e960c9ca
For some reason, the TV series I got on blueray, each disk only has one file that contains 4 episodes. When I put it in as s01e01 - e02 - e03 - e04 it only sees episode 1 and 2, It happens with every disc; s01e05 - e06 - e07 - e08… just episode 5 and 6 is listed.
Would appreciate any assistance with this…
Just put first and last episode ie s01e01-e04
Plex DocumentationYour Media
See the Multiple Episodes in a Singe File section of Naming & Organizing Your TV Show Files.
You may want to split the file into individual episodes. As mentioned in the documentation, multi-episode files appear as individual episodes in the Plex app, but playing any of the episodes will play the full file (i.e. if you pick episode 3, it starts with episode 1).
Many multi-episode files have chapter markers denoting each episode. This makes it easy to split the file into individual episodes. See [HowTo]: splitting multi-episode files with MKVtoolnix GUI .
MKVToolNix Multiplexer tool; Output tab:
Screenshot (1156)
This worked but when I tried it the first time it didn’t, it only listed the first episode and the last episode on the 4… Worked this time and I appreciate it!
