[HowTo]: splitting multi-episode files with MKVtoolnix GUI
The purpose of this HowTo is to split videofiles which contain more than one episode of a tv show into single-episode files. So they show up individually within plex, can be played individually and don’t produce any of the weird things that multi-episode files are plagued with.
The tool used is MKVtoolnixGUI
it is freely available for all major PC operating systems.
Therefore the container format of the output files will be MKV.
The input format can be a multitude of containers like AVI, MP4, MKV, MPEG, TS, DIVX and several more.
The quality of the files will remain the same, because mkvtoolnix only remuxes the files, it doesn’t re-encode them.
  • start up MKVtoolnixGUI
    (depending on your operating system, this might look a little bit different)
  • drag the multi-episode file into the window marked by my crude arrow
  • the video, audio and subtitle tracks it contains will appear in the window underneath it
  • you may want to revise the language code that is assigned to the audio track(s) and the language and ‘forced’ attribute of subtitle tracks so the Plex interface informs you correctly about the languages available.
    Plex’s automatic audio and subtitle track selection feature relies also on these tags to work correctly.
  • change to the Output tab:
  • change ‘Split mode’ to ‘after specific timecodes’
  • input the timecode of the episode break into the field ‘timecodes’ (you can input several timecodes [separated by comma] if your source videofile contains more than two episodes)
    (I chose to split after 25 seconds, because my example file is only 59 seconds long)
  • revise the path and filename in ‘Output file’ to your needs
  • click Start muxing
You should find 2 or more MKV files in the destination path, their file names appended by a three figure number (DVD Introduction-scene-001.mkv and DVD Introduction-scene-002.mkv for our example file in the screenshots)
Now rename the split episode files according to the Plex naming guide for tv show episodes and add them into your library.
Done.
If you set above as ‘Split mode’ = “Before Chapters”, you can split your files on chapter markers.
This is particularly useful when you have ripped tv shows and you got only one monolithic file instead of one file for each episode.
Guide for joining video files with MKVtoolnixGUI
Naming tv show with multiple seasons in single file
How do you manage your media's (naming convention and metadata)?
Separating English and Japanese versions of the same show
Plex is detecting couple different episodes of Adventure Time as copies (I think)
Ripping TV Series DVDs into seperate MP4 files
Astro Boy Ultra Collector's Edition
TV Show meta data issue
Having trouble with adding music videos
Star Wars Rebels S4E15-E16
4k Filme ruckeln
Diividir MKV
Help with Series and Episodes Naming
Multiple Episodes in a Single File (naming) -not working
Match Meta-Data to File Structure
Film "Welt am Draht" ist in IMDb - wird aber nicht zugeordnet
Videos using the multiple parts feature in Plex to not continue to the 2nd part
External Hard Drive Issues with Windows
Not detecting imdb und tmdb-id
How do I Split a TV Show that has Multiple Mini Episodes in one Episode?
Multi-Part Episodes Listed Separately on TVDB But Combined on DVD
Properly name and file mispackaged movies
Pride and Prejudice TV Mini Series
An interesting miss-match by the server (not good for kids)
Indexing TV Shows Incorrectly
How do I delete media from a library without deleting from disk?
Problem with One File, Two Episodes - Can Plex Handle This?
Newby issue two different movies in a series coming up as the same one even though files are different
Help with plex understanding multipe tv epsiodes in one file
I am have problems with the show rod sterling's night gallery
Multiple, non-contiguous episodes in a single file
Anyone know how to correctly Tag Animaniacs (2020)?
I believe Thetvdb.com is wrong for this series
Naming of TV Shows
Multi episodes in single file
Matching a miniseries from a BD that has all episodes combined into one file?
Videos endlessly buffer at/near the end of playback
Adventures of Gummi Bears
Camomile Lawn DVD has different number of episodes to TVDB and IMDB
Question on file naming for a tv show with an odd file
Episodes matching between TvDB and TMDB failes across seasons?
[Anleitung] Deutsche Filmtitel und Beschreibungen v4
Playing TV shows where a single file contains many episodes
Is there a way to sorta TV seasons differently per season?
When Calls the Heart - Year 5 - DVD naming?
[HowTo]: joining multi-part movies files with MKVtoolnix GUI
TV Shows naming file
Frage zur Benennung von Mehrteilern
File Splitter Advice Needed
Recommended software to rip blu rays
How to name single file multi-episode, but out of order?
Combined episodes in a single file issue
Programm um Folgen zu schneiden und zusammen zufügen?
Thundercats
please feel free to add other guides and software to split episode files into other target file formats. But please add whether the method employs pure remuxing (quality of the file stays the same) or re-encoding (quality is diminished)
this software supports splitting losslessly too, if setup correctly (it is a ffmpeg GUI):
https://forums.plex.tv/discussion/118791/dmmediaconverter#top
Nice writeup, this is likely to help a lot of people out. It would be good to mention also that this is a great tool for doing the reverse (joining 2 files together) as well. :slight_smile:
You are the man.
Perfect subject.
Many people need this.
This is wonderful thank you! I still dont understand why cartoon stuff (where 2 “episodes” air together in 1 time block always ) are listed separately like this. Officially they only have 22-24 episode seasons and this makes each season have double the episodes
I’ve used MPEG Streamclip to split episodes for years. You trade being able to visually select where an episode ends for being able to split it in one action, I guess. It’s also easy to make cuts on keyframes, which I’m used to do after editing lots of EyeTV TS files. Does MKVtoolnix handle this differently, or is this not an issue with H.264 files? It is annoying to not be able to split a file exactly where you’d like to.
Cutting at exact keyframes would require the h.264 videostream (at least partially) to be decoded and then cut and re-encoded again.
mkvtoolnix does not do this. It cuts at the nearest I-frame.
But I don’t consider that an issue, since most double-episode files have at least one or 2 seconds of black between them.
My method is about preserving the quality and making no change to the data streams whatsoever.
If you need exact cutting, use a different means.
VideoReDo would be such a program which can cut quite exactly.
Thanks. I’m so used to streams breaking without cutting at keyframes, I just assumed. I gave it a quick try and it worked fine. It’s splitsville for you, Curious George.
First, thanks for writing this tutorial. I’ve tried multiple different methods to get MKVToolNix to do what I want, but I don’t seem to have any luck.
I have some multi-episode mkv files that are 3-5 episodes each. I tried using the comma method to separate timecodes according to the format provided, but MKVToolNix only outputs one file at the specified timecode for the first file and ignores the rest.
For example, my Timecodes box reads:
00:24:34.25,0:48:58.25,1:13:21.25
MKVToolNix only muxes one file at 00:24:34.25
Can anyone advise on how to get it to behave properly?
Thanks.
Make sure you’re using “after specific timecodes” and your maximum number
of files is set to 0.
“after specific timecodes” is checked
max number of files is/was set to “unlimited.” 0 isn’t an option.
Ha, sorry. I’m a dummy. Yes, unlimited is correct. Other than that…I
don’t know what could be wrong
Just tested it and it worked here.
Have you tried to ‘pad’ your timecodes with leading zeros?
00:24:34.25,00:48:58.25,01:13:21.25
Hace you updated mkvtoolnix?
Yeah, updating would be good…
Yes and yes. I can post my output log if anyone’s interested. It doesn’t show any errors.
If your source file is not a MKV yet, try to mux it into a MKV first, so the file has proper timestamps.
Then repeat the ‘split’ attempt.
They are mkv files.
Try remuxing it entirely anyway! Maybe that’ll fix something.
That seems to be the problem. I tried a different MKV file for comparison, and it worked fine.
Is this a good walkthrough to follow so I can remux without any loss in quality?
https://support.plex.tv/hc/en-us/articles/201097958-Remuxing-Files-to-MKV
if the source is a MKV, all you need to do is to drag it into MKVtoolnixGUI and hit ‘Start muxing’
