Using the Plex Plug-in 2.1 framework to support a media that is split into 2 parts.
Once the first part is finished the second part start but will end within 1 min (even if the second part is 57 min).
I have verified both parts using VLC and they play just fine.
The code for creating the media is below:
track = TrackObject(<br />
title = itemtitle,<br />
key = itemlink,<br />
rating_key = MUSIC_PREFIX + "/" + unitid + "/" + broadcastid,<br />
thumb = channellogo,<br />
duration = duration<br />
)<br />
media = MediaObject(<br />
audio_codec = AudioCodec.MP3,<br />
)<br />
for brfile in item.getiterator('broadcastfilename'):<br />
brid = brfile.attrib.get("broadcastid")<br />
brdur = int(brfile.attrib.get("duration")) * 1000<br />
brlink = baseurl.replace("[broadcastid]",brid)<br />
Log.Info("brlink %s dur %d", brlink, brdur)<br />
media.add(PartObject(key = brlink, duration = brdur))<br />
track.add(media)<br />
dir.add(track)
Is this a known issue or is there something obvious wrong in the core?
Full source code can be found here: [SRPlay.bundle](https://github.com/henriksp/SRPlay.bundle)
Some additional info. When having multi-part media, even the first part will fail after about 1,5 minutes.
After turn on additional debug in the Plex media center I have been able to find the following problem:
16:28:56 T:2955980800 M: 0% DEBUG: CAnnouncementManager - Announcement: QueueNextItem from xbmc
16:28:56 T:2901484224 M: 0% DEBUG: CFileCache::Open - opening <http://sverigesradio.se/topsy/ljudfil/utan/statistik/4173775.m4a , http://sverigesradio.se/topsy/ljudfil/utan/statistik/4173800.m4a> using cache
16:28:56 T:2901484224 M: 0% WARNING: CreateLoader - Unsupported protocol(stack) in stack://http://sverigesradio.se/topsy/ljudfil/utan/statistik/4173775.m4a , http://sverigesradio.se/topsy/ljudfil/utan/statistik/4173800.m4a
16:28:56 T:2901484224 M: 0% ERROR: Open - failed to open source <stack://http://sverigesradio.se/topsy/ljudfil/utan/statistik/4173775.m4a , http://sverigesradio.se/topsy/ljudfil/utan/statistik/4173800.m4a>
16:28:56 T:2901484224 M: 0% ERROR: Init: Error opening file stack://http://sverigesradio.se/topsy/ljudfil/utan/statistik/4173775.m4a , http://sverigesradio.se/topsy/ljudfil/utan/statistik/4173800.m4a
16:28:56 T:2901484224 M: 0% ERROR: CAudioDecoder: Unable to Init Codec while loading file stack://http://sverigesradio.se/topsy/ljudfil/utan/statistik/4173775.m4a , http://sverigesradio.se/topsy/ljudfil/utan/statistik/4173800.m4a
So the problem looks to be that the created stack of both media parts are given as input and that the FileFactory fails (at the end) to create a handler based on the protocol (should be http but becomes stack due to more than one part).
So it looks like the support for multi-part media is not really in place, or?
I have also included the log file from Plex after enabling additional debug.
While waiting for someone to respond I have done some more debugging.
It looks like the calculation of time when having a stack is incorrect since the following statement in PAPlayer.cpp becomes true:
// check whether we should queue the next file up
if ((GetTotalTime64() > 0) && GetTotalTime64() - GetTime() < TIME_TO_CACHE_NEXT_FILE + m_crossFading * 1000L && !m_cachingNextFile)
This trigger the next file (also a stack) to be cached and then everything goes wrong.
I will continue my debugging…
