Multiple epg sources, for those with multiple tuners
Hate to ask this, but did you remove all of them before you started the process? You have to remove all your tuners. Once that is done, then open enough tabs / browsers for each of your tuner, then open up your PMS in each tab / browser by clicking add device. Do that for each tab, that starts a separate session. The trick it to have a session open for each tuner or this doesn’t work.
Am thinking of setting up a DVR solution with a HD Homerun. Am located in the NE of Ireland, along the border between Co. Down & Co. Louth , so will be receiving signals from both the Irish Saorview and UK Freeview platforms. Being able to use epg data from both is pretty much essential if one wants to set up recordings etc.
So this service enhancement most definitely gets my vote.
+1 Why this wasn’t implemented by default is beyond me. I have a multiple countries from the the same tuner.
+1!
C’mon Plex, pull 'ur finger out and give us this feature. Otherwise, my feeling of wasted money on the Plex pass is real.
We all bought our Plex Passes because Plex provided the guide data: only to have the rug pulled out from under our feet when Plex pulled that feature to force us to xml guide data. That done; the least Plex can do is provide a solution that works for all us subscribers that need to incorporate multiple guide sources. If you can deal with multiple time-zones, that would also help.
+1 - This would be super use full… multiple zip codes + xml guides.
Please add this feature!
+1 For me!!!
Yes this functionality would be Awesome, i was able to do this with Kodi and NextPvr, i switched to Plex because NextPvr didn’t actually work reliably with the tuner even though the EPG was excellent. i had it linked to the EPG Service that cost 25 dollars a year, can’t recall the name at the moment.
i use Knoxville as my primary over the air, but would also like to pull in EPG data for Chattanooga.
+1 Would be awesome
Can we at least get the ability to rename “Live TV & DVR” ?
Different requests need their own thread.
Once you create the second live TV DVR section is there a way to modify the tuners for each live TV DVR section? Or once it set it’s done?
This.
Unless you have two PMS’s each with their own tuners; then they can each have their own guide.
Hi darcilicious, I was referencing the live TV and DVR duplicating mod. I’m guessing once you’ve set it up there’s no way to go back and modify the tuners unless you keep both setup windows open:(.
Edit, sorry I did not see the word this lol.
You are correct, you would have to remove all the tuners and start over again. You can setup groups, say 2 tuners for one source and 1 tuner for another (in that case you would just start 2 sessions). Good thing is that really doesn’t affect anything because all your recordings will still be setup to record once you add back your tuners.
Cool thanks!
+1! I have xTeVe for OTT plus DVB-C for local FTA channels. Still struggling with getting combined EPG without additional script magic… Why not to allow separate EPG per tuner??
+1 Separate EPGs per tuners… please.
I’d happily buy my plex pass again, just for this.
+1 for this please!
+1 for this too
