Multiple recordings of the same programme
Hello since the last couple of server upgrades, I seem to have an issue with Plex recording the same show multiple times. For example:
If I set it to record a show at 2100 on Channel 4 HD. I’ll get that, plus the same show at the same time in Channel 4 SD, it’ll also record the same show an hour later at 2200 on both Channel 4 HD +1 and Channel 4 SD +1. So I end up with four versions of the same show!
Other than going in the advanced tab each time and selecting 2100 and the HD channel is there another way of Plex just recording the one version I want? This does seem a bit mad…
Thank you.
