This was mentioned 6 months ago and still happening. Any ideas?
The issue remains outstanding. Some channels have some programs that are in the EPG as shows as opposed to episodes - this makes it impossible in our current implementation to identify that the SD and HD and +1 airings are actually of the same episode.
It is on the list of future developments. The only option now if you wish to record programs that appear in this way - they tend to be mainly News - is to disable the +1 channel and the SD channel if you want HD or vice versa
