Music Local Artwork naming conventions
Server Version#: 1.14.1.5488
After setting up my music folders and finding some didn’t get automatic artist poster artwork matches, I realised that (unlike some support article template suggested) I want album folders within artist folders. And I really want to automate it as much as possible (particularly since I have 2 duplicate servers on 2 PCs for times one or the other are unavailable).
I’ve seen differing music artwork naming convention templates, and I want to use the optimal one. Is it:
Music /
Artistname /
Albumartist - Albumtitle /
Disc 1 /
01 tracktitle.flac
24 tracktitle.mp3
Disc 2 /
01 tracktitle.flac
09 tracktitle.mp3
I’ve seen the “cover” files sometimes suggested as “poster” files; is “cover” better?
Or is OK to somehow prefix the artwork file names so it’s easier to make sure they’re put in the correct folders? (For example Artistname-poster.png and Albumartist-Albumtitle-poster.jpg ?
Does album artwork need to be in both disc 1 and disc 2 folders?
May I assume that disc subfolders can be omitted for single-disc albums?
I’m using mp3tag (after some frustrating trial-and-error I think I realized that if I manually tag multiple poster files, Plex uses 3/3 instead of 1/3!). Is there any way to mp3tag files with background art in addition to poster art?
Is
01 Trackartist - Tracktitle.mp3
better than
01 Tracktitle.mp3
Thank you in advance very much!
Edit: Aaargh; initially my indented-folder-trees worked but now I see the indenting is gone.
Here are some tips regarding music
multi-disc albums
handling singles and EP’s
https://forums.plex.tv/t/best-way-to-add-album-singles-ep-to-a-premium-music-library/128108/8
possible ‘side car’ files for music
soundtracks and ‘various artists’
Thank you very much Otto, while reading many threads I saw some of those, great to know to take those as authoritative.
1.
There was disagreement between your 2nd and 3rd links about whether to call the album folder’s main image (i.e. the album’s cover image) :
are both equally good?
2.
I’m confused by:
|–Albumartistname /
For artist-poster.jpg and artist-background.jpg did you mean artistname-poster.jpg and artistname-background.jpg ? (Or to literally use the word “artist” in each?)
3.
One question I have left after reading those threads:
^^^ this
No, Plex reads embedded pictures only as ‘album’ cover art.
Everything else can only be done with “sidecar” files.
Thank you very much Otto for answering my every question!
In case anyone is interested, here’s what I’ve learned (I’m excited to implement it!):
Plex-Music-Template
One more question please. Almost everything worked perfectly once I used the proper artwork naming conventions (and also mp3tag-ed album poster-art into tracks).
Except in 3 similar cases the folder-2 image got used instead of the folder image. (Note that I Enabled “Use embedded tags”, and in each case the folder image was mp3tag-ed 1/2 and the folder-2 image was 2/2; swapping the order of the tagged images didn’t help.)
In each case the images are in the folder with the audio tracks.
Case 1:
Plex used folder-2.png instead of folder.jpg (folder.jpg tagged 1/2 and folder-2.png tagged 2/2 in all tracks)(no disc subfolders)
Case 2:
Plex used folder-2.png instead of folder.jpg (folder.jpg tagged 1/2 and folder-2.png tagged 2/2 in all 4 disc subfolders)
Case 3:
Plex used folder-2.png instead of folder.png (folder.png tagged 1/2 and folder-2.png tagged 2/2 in tracks in all 4 disc subfolders)
(Of course I imagine just getting rid of the folder-2 images would solve this, but I very much want to learn if there’s a better way!)
I can’t tell you. Only log files from around the time when the metadata of these items were downloaded the first time could shed some light on this.
Thank you very much Otto. I’ll figure out how to post log files and do another test run with just the 3 albums.
Please find my logs attached.Plex Media Server Logs_2019-03-07_09-06-34.zip (2.0 MB)
Thank you very much Otto!!
Edit: One more issue to note (that I thought went away but came back with this load) if anyone is willing to take a look at these logs is that one of the artist-poster.png images didn’t get recognized by Plex.
Can anyone please suggest where I should start looking in the log files to discover what the issues are?
