Music Replay does not work on iOS App
Good evening, I have the following problem: I have the Replay button on the PLEX app, but the music is not repeated, it does not work regardless of what I do, does someone have a solution or can test it?
I want to play music one at a time repeatedly
Server Version#:1.19.5.3112-b23ab3896
Player Version#: 7.5
Just tested that on my own iPhone.
  1. I picked a song
  2. clicked on Play
  3. opened the playback modifier screen
  4. I set the repeat option to “repeat-1”
  5. the song played
  6. the song played again
  7. the song played again
Works for me as described in the related support article: https://support.plex.tv/articles/205671108-media-playback/#toc-1
On what version of iOS are you experiencing this not working?
Now it worked by activating the old player in the settings under advanced - without this setting it doesn’t work for me
I’m using the default player without issues (not the legacy mode you’re referring to).
Not sure what fancy audio format might not play as repeat-1 shouldn’t really depend on the player itself
I only have .mp3 files, have had the problem for several years …
I deleted the PLEX app, reinstalled it - the menu looks different and it works now
