Server Version#: 1.22.0.4163
Player Version#: Plexamp mobile 3.4.4, Windows Plex 1.29.0.1885-67668ec3
Hello, I’m a fairly new PLEX User, and have been trying to move towards using it as a music player. However my server seems to have issues with music. The music will occasionally skip and stutter (every minute or two, sometimes goes a few min. without happening). If you’ve ever listened to music with a portable CD player you will know what i mean, the music will suddenly go back a few seconds. Its very jarring and basically takes all of the enjoyment out of listening
The files are mostly FLAC but there are some mp3’s mixed in
Hardware is as follows:
CPU: Xeon 1230v2
MOBO: ASUS P8Z77-V_LK (bios ver.1001)
RAM: 16GB DDR3L PC3-12800 (4x Hynix HMT451U6DFR8A-PB modules)
Storage: OS is on a SATA SSD | Plex Metadata is on a NVMe SSD | Plex libraries are stored on a Stablebit Drivepool of HDDs | Transcode directory is a 6GB RAMDisk
GPU: FirePro V5900 (Not used for plex or transcoding, but figured i’d note it)
The server isnt starved for resources, All i run on it is PMS, Tautulli, a Windows 10-N virtual machine(with 4gb ram and 3 cpu threads allocated), and some shared files
Any advice would be greatly appreciated! Thanks in advance
