My older HDHomeRun for OTA no longer shows in Plex, works fine with HDHomeRun app
Server Version#: 1.25.9.5721
Tuner Make/Model: HDHomerun
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Anyone know of anything to try to get this working? I have tried rebooting and checking wires. I know it can’t be just my network as everything else works great and the HDHomeRun works fine with the HDHomeRun app.
It was working fine last football season. I recently upgraded my fiber internet from 500Mbps to 1Gbps (same ISP) and mesh router from Eero 5 pro + Beacon to 2x Eero 6 pro. HDHomeRun is wired through a 1Gb switch (same as it was when working).
Have you checked the HDHomeRun has any updates? I check mine every 2 months just to make sure (and usually it has an update each time) Just a suggestion.
If it is a HDHR Dual then it uses the ‘Plex Tuner Service.exe’ which Plex has been chasing a crashing problem for most of 1.25 versions.
Try a full reboot and try again.
Still doesn’t work, updated, rebooted and reinstalled HDHomeRun. HDHomeRun app works great and I can watch TV on that, but Plex still doesn’t see the HDHomeRun. Next I’ll try a different PC. Sucks as I can’t use my Plex lifetime pass for DVR until I get this resolved.
