ive been using plex for some time now and i recently set up a new rig and im having MAJOR problems with plex that seem to be unique to me. I installed the most recent version, i dont use a VPN so that isn the problem, on the local side, FROM the plex program, it tells me to download plex media server, and from the web side, nothing shows up but the preinstalled channels. Ive tried downgrading, uninstalling and reinstalling, outside of some matches and gasoline i dont know what i can do to fix it. heres some info if you need it
ryzen 5 2600x
amd vega 56 OC
windows 10
any advice is much appreciated.
Server Version#:1.16.3.1402
Player Version#: 3.104.2
Are you trying to add your own files and Plex wonāt recognize them?
=> if thatās the case, please share some more details how your files are structured/named and connected to Plex
Do you miss some libraries previously shared with you?
=> you might need to double check with the friend who shared his media with you if they still do and/or make sure you still use the same Plex Account
Are you looking for media via plugins?
=> Plugins Are currently being phased out and are no longer directly accessible from most Plex apps (at least those used to stream various media)
I canāt even get that far. When i start the server it says it cant find the server and that its look for it ( it never does find it) and when i go to the local side, to add my media, it just says download media server, so i canāt get as far getting them to recognize. Itās almost like the server doesnt know its a server.
This is the rub, i logged in with a friends info, and their setup works fine on my pc, so its something specific with me.
ex: Your server should point to āC:\Users\yourwin10user%\AppData\Localā. In this folder, you will find the Plex Media Server folder which essentially contains all your plex media data. If that folder is not there, go onto the computer that has that data, copy and paste it to that location on the currently used hard-drive.
Thx!
Do you get the same result wether you use http://127.0.0.1:32400/web or https://127.0.0.1:32400/web to load the server?
I havenāt been using Windows for some time so I didnāt recognize all the apps in your icon tray⦠do you have any security apps running in parallel that might interfere with the Plex client interacting with your local server install?
In that case Iām running out of ideasā¦
Could you maybe look for your serverās logs and attach them here? Considering the state of your server, youāll have to collect the files manually.
@tom80H im happy to report i FINALLY got it working. the keys were attached to my previous account, i deleted them and it instantly picked up my stuff! thanks so much for the help.
