Server Version #: 1.41.4.9463
Player Version #: N/A (web app doesn’t load)
NAS Model: Synology NAS (DSM 7.x)
Network Setup: ASUS router | QuickConnect enabled | Port 32400 manually forwarded
Description
I’m running Plex on my Synology NAS and have been stuck on an issue where the Plex Web App never loads. The package installs and starts up fine, but clicking “Open” from Package Center or visiting http://::32400/web just results in a blank white screen that spins indefinitely — no errors, no timeouts.
I’ve tried multiple browsers (Firefox, Safari) and tested both locally and remotely, with the same result.
What I’ve Tried
Restarted both NAS and router
Uninstalled and reinstalled Plex several times
Tried static IP/DNS and DHCP
Forwarded port 32400 on both NAS and router
Configured firewall for Plex, then disabled DSM firewall entirely
Removed all Plex-related port forwarding and firewall rules to start fresh
Verified that other Synology apps load normally (Photo Station, Docker, etc.)
Confirmed NAS connectivity via ping and QuickConnect
Additional Notes
I can connect remotely through QuickConnect and other apps without issue.
I read that QuickConnect can sometimes interfere with Plex’s web interface, but disabling it requires SSH, which I haven’t tested yet.
I also tried installing Plex manually using the SPK package from Plex’s website (rather than the Synology-hosted version, which can lag behind). Same issue — installation succeeds, but the web app never loads.
What I Suspect
Some kind of internal DSM firewall or network binding conflict that’s blocking Plex from serving the web interface
A QuickConnect or VPN routing issue that’s preventing access on port 32400
A stale configuration or permission file left over from a previous Plex install
Next Steps I’m Considering
Disable QuickConnect temporarily via SSH to test direct LAN access
Review DSM firewall and network interface settings for hidden or automatic rules
Reinstall Plex in Container Manager (Docker) for a cleaner network environment
Question
Has anyone else run into this on Synology — where Plex runs but the web interface never loads (blank page indefinitely)?
Any ideas or known fixes would be greatly appreciated!
