Hi all,
Plex connect is installed and working great.
However my netflix app and airplay has now stopped working on my ATV3.
What is the fix for this please?
Thanks for all your help
Alex
Hi all,
Alex
Settings.cfg file contents?
logs?
What is the error received?
SETTINGS.CFG
[DEFAULT]
And when you switch the DNS in the ATV3 back to your routers DNS IP? Does Netflix work then? PlexConnect will not, but just to test your setup.
That’s your atvsettings.cfg not your settings.cfg, before were you using a DNS redirection service to spoof you were in the us?
Sorry, i realise my mistake.
My DNS is currently 8.8.8.8 --- the default. When i switch the router back netflix does work and as you said PlexConnect does not.
If i go into my settings and change the DNS to my routers DNS settings that should fix it, correct?
I haven't been using a DNS spoof no.
That should work.
