Navigation pulling from previous Libary used when changing tab view
Server Version#: 1.25.7.5604
Player Version#: 8.31.0.31311
I’m seeing an odd issue with the Plex client on my Fire Stick when navigating in the app. I have several libraries of different types on my server pinned on the sidebar and what is happening is I’ll be looking at one library and I change my view (at the top tabs) and then when the new tab appears it is not for that library, but the previous library I was in before this.
Settings:
  • Reduce Motion: OFF
  • Remember Selected Tab: ON
So to give an example of how this plays out:
I’m on library A and viewing the main Library tab (of all items) and then go to the sidebar and select library B and it opens to the Recommended tab since that was the last one I had used. I go to the top and choose the Library tab there, but instead of the titles of library B, it shows the view from library A. If I click the Library tab again it then reloads and now shows the correct titles. But if I navigate to a different library (we’ll call it D now) and change views, the same thing happens – it loads the titles for that view from library B since that was the previous one, instead of D library I am supposed to be in.
I rebooted the Fire Stick and turned on logging as well.
Attached is a section of that logs which I believe covers the app launching, and my attempts at navigation after that.
log_snippet.txt (62.8 KB)
This issue is resolved for me with the 9.0.x clients.
Considering the fast turnaround I suspect Plex was already aware of the issue at the time.
