[Need Help] Why i am having this message in Plex Web
Hi Guys!
I re-install plex and i got this message:
Any Plex Web settings and customization made in this Plex Web instance will not be synchronized with other Plex Web instances. This is because we have detected you have previously saved settings from a newer version of Plex Web
see:
I am wonder why? I am using latest plex beta version
THX for any help :slight_smile:
Braz.
Have you used the hosted version, app.plex.tv? It is always the most recent, and currently at v4.39.1.
There are probably some features and/or settings that are not backward compatible with 4.34.4.
Uh… I will check that
Thx for the help!
Yeah! you are right! my app.plex.tv is 4.39.1
So… What can i do?
I use app.plex.tv as it is the most recent.
The version bundled with PMS always lags by a few releases.
You can see the differences on the announcement thread.
