Need some help troubleshooting this problem
I want to apologize first time here if this is in the wrong place
I have a curious question I want to say no, but it doesn’t hurt to ask does the client need to open the port on the router, or just the server I have two friends outside of my Network one lives in Texas, and one lives in Florida. The one that lives in Texas is having a hard time playing any of my videos while the other one can play natively no problem. But he has no problem playing Disney+ on 4K.
In the settings dashboard you can monitor what’s actually happening with any stream that’s playing. This is the best place to start
This will tell you if you have an indirect connection or something is transcoding and the required bandwidth of what’s playing. Best case scenario is that both your friend show “remote” and “direct play”
56088464-7a5f3d00-5e4f-11e9-8faf-204bff620660
If it looks ok and one person can play everything fine, your other friend might just not have the bandwidth to handle your stream
You can get away with 20mbps download speeds when you stream Netflix or Disney+. It’s likely those servers are also much closer to his house. You may have movies that require over 100mbps. Tell him to check his download speed
In the settings on your friends player under “Remote Quality” tell him to switch to Original or Maximum. The default is usually set too low at 2-4mbps.
If the person is trying to watch 4k movies on his phone it’s going to transcode no matter what you do.
If the person uses a browser tell them to try the Plex for Windows or Plex for Mac app. It’s a better player with better support for direct play
I don’t know what kind of server you’re running. Some servers can do 30 transcodes with no problems and some can’t even do one
These are just generalized guesses. You need to do some investigation with specific files and see exactly how they’re failing to get a cut and dry answer
I am running windows, 11 cpu thread ripper gpu 3060
I will try those settings but it buffer on direct play and on hardware, accelerated only on him my bandwidth for my server is 1gb up/down
His upload speed is 60mb down and 10up I think that what it was when we were testing on multiple devices, we try to tv, his laptop, his phone all does the buffering thing we even test his phone on his 5G connection same thing
