Server Version#: Version 1.26.2.5797
Player Version#: Version 4.81.1
This has been a problem for quite some time (feels like months) so versions above don’t really matter. Its definitely worked in the past as I’ve used this filter from time to time.
Do the following steps:
- Within a TV Library which has ALL episodes matched, open up the advanced search filters.
- Now select episode unmatched and set it to true. Nothing is displayed, this is correct.
- However, now change this to false.
You should now see a list of everything which is matched but you don’t it remains empty with nothing displayed.
If you go to something like trash or episode duplicate in the advanced search then the negative/reverse search works as expected. This type of searching is useful to admins and should be fixed.
